Soft top coming loose at rear doors
Old Sep 6, 2011 | 06:29 PM
Navyvetnorwich91's Avatar
Veteran: Navy
Default Soft top coming loose at rear doors
I tried searching and just don't seem very good at finding stuff on point. I have the soft top and find that when I put the side windows back on, they won't stay tight at the rear doors. That right-hand bend that's supposed to stay tight seems to come loose from the wind when I drive. I know it must just be me because a gazillion people have soft tops without any problem. Anybody know (i) if there is some trick to keeping the windows tight inside the door jam or (ii) if I might just be being stupid? Thanks very much.
- Confused in Massachusetts
Old Sep 6, 2011 | 06:40 PM
upwings's Avatar
Mine's doing the same.... noticed a velcro sound when driving. Then I noticed the windows coming out. I will see what I can track down. The top was new for '11.
Old Sep 6, 2011 | 06:42 PM
Veteran: Navy
Hey thanks for checking into it. I appreciate it.
Old Sep 6, 2011 | 06:45 PM
wired's Avatar
Mine is a 2010, and I hear the velcro loosening while on the hi way. The top tends to get slightly bigger when it is hot out. Check if it gets loose when it is not very hot ouot.
newtdog's Avatar
I'm having the same problem on the driver's side. I hope someone can help us.
Old Sep 6, 2011 | 06:54 PM
Veteran: Navy
Hey wired, I did notice that it seems to come loose more when it's warm out. Today it was cool and rainy and I had no problem with it.
Old Sep 6, 2011 | 08:42 PM
Cedo Nulli's Avatar
There is a groove on the vertical piece of the door surround that the leading edge of the window goes into. This will cause the leading edge of the window to wrap around part of the surround and not merely sit between it and the door. Take a closer look at your manual.
Old Sep 6, 2011 | 09:04 PM
Noxian's Avatar
x2, gotta make sure its tight and in the groove, no problems on my 2011 hot or cold with windows coming out.
Old Sep 7, 2011 | 08:29 AM
Veteran: Navy
Thanks guys. I'll check it out. It happened to me again today. It'd be great to fix it. Thanks again.
Old Sep 7, 2011 | 09:58 AM
derfc's Avatar
This. Yhe edge of the window panel wraps around the door surround. If it's not correctly in that channel, it'll open up like you are describing.
