Spiderwebshade
Old May 16, 2012 | 08:07 PM
  #21
jjntj2003's Avatar
Originally Posted by FlameRedJK
This looks like I could keep it on and my soft top would go right over it right??
Think I will be investing in one of these soon!
Yep hard or soft top goes right over so you don't have to ever take it off.
Old May 17, 2012 | 07:50 AM
  #22
FlameRedJK's Avatar
Oh yeah this is definitely happening then
Old Aug 6, 2012 | 05:56 PM
  #23
cosmokramer's Avatar
I installed this when I installed my Trektop. Such a great difference. I went from hardtop without spiderwebshade to my current set up and I love it. Nice thing is, as mentioned, don't need to remove it at all.
No problems with gaps or anything, it's just hella comfortable and the Houston sun is tolerable. I notice I use sunrider position about 300 times more often because the wind and sun are cut down to a comfortable level. Definitely prefer top down to the bikini top position which blocks out all sun.
Did I mention how much I love this thing? I got theore expensive trail mesh for durability.
Old Aug 6, 2012 | 06:27 PM
  #24
Jeeper'08's Avatar
Love my SpiderWebShade!
Old Aug 9, 2012 | 12:08 PM
  #25
nwatkins's Avatar
I have a spiderwebshade and hard top. How do you get the freedom panels on when the spiderwebshade is completely installed? I have to undo the front part of the shade (3 small spider balls) and pull the shade back in order to latch the freedom panels by the windshield.
Old Aug 17, 2012 | 03:57 AM
  #26
SilverEagle's Avatar
Default Spidershade
Yea I have the same problem,seems I"m missing out on something.I contacted Spidershade people and they said it sould"t be a problem but I haven"t figured it out yet??
Old Aug 17, 2012 | 04:05 AM
  #27
matprovo's Avatar
I don't have a hard top but for my soft top I removed the two spider balls that attach at the latches. So I have one on each corner and one in the middle. Works perfect. I don't even reattach the other two when I take the top down. Really no difference. Doesn't flap around or anything.
You could try that even though you have a hard top.
Old Aug 17, 2012 | 05:13 AM
  #28
RedJupiter's Avatar
Originally Posted by JKatfish
Yeah, mine had a gap too, so I added some grommets and bungee balls from Harbor Freight for $10. Much tighter and seems less noisy and flapping since I run it with hardtop on and Freedom Panels off. Works great with windows down tho!
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=316935"/>
There is almost no gap if you use the three short spider balls in the front. And the longer spider balls can be positioned inside the plastic trim at the very corners of the front. I found it easier to install the corner ones, sliding the bungee cord as far forward as possible, if I first undid the front of the door surround and moved it away from the roll bar.
Old Aug 17, 2012 | 07:01 AM
  #29
Meauxpar's Avatar
Yeah I am also curious of this. If I don't have to take it off I will get some.
But I don't see how you install the freedom panels with that in the way.
Any of you hardtop guys know the solution?
Old Aug 17, 2012 | 11:28 AM
  #30
poopworker09's Avatar
Originally Posted by Wartoy
Mines treated me well for about a year now
I think i like that set up, I might just order one for a 4 door, to put on my 2 door.
