Squealing when I start...
Old Oct 17, 2017 | 03:11 AM
09orangesahara's Avatar
Default Squealing when I start...
I have an '09 Unlimited that has been squealing when I start it up. I noticed it a while ago but it was less frequent. In the last couple of days, it has happened almost every time I start it. Any thoughts out there JK world... Thanks!
Old Oct 17, 2017 | 03:36 AM
rob_engineer's Avatar
Classic sign of either a bad belt or a bad bearing, likely on the water pump. Does the pitch of the squeal change with rpm?
Old Oct 17, 2017 | 04:21 AM
casamtb's Avatar
Same questions as Rob. I had an issue where the starter wasn't fully disengaging the flex plate on start and made a god-awful grinding cat dying metal on metal noise. If the noise sounds like that and then goes away. Might be the starter is crunk.
Old Oct 17, 2017 | 05:06 AM
resharp001's Avatar
Loved
Community Favorite
I've not had this issue yet on JK, but from several other vehicles I've had to replace it on.....I'd take a look at belt tensioner pulley to start. If you relieve the tension and pop the belt off, you should be able to give the pullies a spin with your finger and spot the bad one very quickly. More often than not it's the tensioner pulley.
Old Oct 17, 2017 | 06:19 AM
Arson's Avatar
maybe try some belt dressing first????
Old Oct 17, 2017 | 06:40 AM
resharp001's Avatar
Loved
Community Favorite
If it is the tensioner pulley, looks like you can replace the pulley itself for $17.....whereas a lot of times you have to replace the full tensioner unit. Even then, the unit is <$50.
Old Oct 17, 2017 | 09:54 PM
Mark Doiron's Avatar
What others have written. Just wanted to add that one of these can be your friend when tracking down noises ...
https://www.amazon.com/Lisle-52500-M...7s+stethoscope
Old Oct 18, 2017 | 04:46 AM
Canvas's Avatar
Veteran: Navy
I have seen this a couple of times on other vehicles and it can be the A/C clutch.
