Standard and water crossings
I have an '08 JKU Manual and I know I am suppose to choose my gear before entering a water crossing. I know that the Clutch can suck in water and mud when shifting.
Is there a breather line I can make or extend to keep this from happening?
There is a slot in the bellhousing under the clutch that allows clutch dust etc to escape. Water and mud can get into this while under water, so any disengagement of the clutch will cause this stuff to go in between your clutch plate and flywheel.
Also, read up on raising your other breathers (front and rear axle and transfer case).
I was more worried about needing to shift lower during the cross. I will follow lead and just go with 2nd gear to be safe. I now understand how this scenario could go. Thanks for the input.
I guess I need to buy a Transfer Case then so I can at least have 2LO ... I was planning on getting the front axle first, But I'll get the Tcase first now that I got a better job.
