Stupid Question, do I need a new driveshaft???
Old Oct 26, 2010 | 09:46 AM
07XMan2Door's Avatar
Default Stupid Question, do I need a new driveshaft???
Hey guys (n gals), I'm new to this Jeepin thing & want to do this right.
I've got the Terraflex 2.5. The rear was a bit saggy so I slipped in a 1" disc. Now she sits pretty level & I'm happy with the overall height of my Jeep.
I have searched on here quite a bit. Seems like half say I need a new rear drive shaft & half say I don't. The angle looks pretty steep to me.
Also some talk about rotating the entire axle so my pinion ligns up better. Could I just cut my upper controll arms & weld in the proper length piece. (I'm assuming it would be better to lengthen the upper so that it moves the rear tire away from the pinch seam)
Perhaps this rotation will not effect the overall center of the wheel
Thinking that rotating the axle is going to jack up my spring & bumpstop alignments?
Which is the best aftermarket adjustable upper control arm & drive shaft?
Also, why in the heck isn't the rear diff a high pinion like the front? That would solve everything.
Thanks for your time & please forgive my ignorance. Any help would be greatly appreciated.
Old Oct 26, 2010 | 09:54 AM
dmhines's Avatar
Just buy some spares from the for sale section of the board and run it until it breaks ... that is what I'm gonna do ...
No sense rotating the axle since I hear the CV boot normally tears at the Transfer Case ...
I just put a Rancho 4" on ... and Rancho told me they have seen no issues with their lift on a 2-door ... Really gonna depend on how much flexing you do I suppose.
Old Oct 26, 2010 | 09:57 AM
Wow, I thought if it were at a bad enough angle to cause the axle to break it would certainly be doing damage to the transfer case & pinion at the same time.
Thanks for your input Sir!
Old Oct 26, 2010 | 10:16 AM
dmhines's Avatar
We are talkin about the rear driveshaft failing on lifted 2-doors.
Old Oct 26, 2010 | 10:35 AM
Yes the rear, what do you know about this? What do think I should do?
Thanks
Old Oct 26, 2010 | 11:13 AM
dmhines's Avatar
Thanks
Like I said above ... keep a spare handy ... and see how long the original one lasts. I have read some folks have them fail in the first 1000 miles ... others have never had them fail ....
The only other was is to replace rear shafts with aftermarket shafts, change to u-joints, add adjustable control arms and possibly move your spring mounts ...
Old Oct 26, 2010 | 04:22 PM
Kinda hate to wait for it to break if I can make it better now, but I hear ya. Thanks for the reply.
Old Oct 26, 2010 | 04:44 PM
Abacabb's Avatar
Run your drive shafts until they go bad.
I've been running my stock drive shafts over 80k miles with a 4" lift.
But recently I was getting a knocking sound while in 4WD. So I'll be replacing the front with a Tom Woods Drive Shaft in the next few days.
Old Oct 26, 2010 | 04:52 PM
Seems to be the going answer. Will I have some warning B4 I'm stranded?
