Supercharger or turbo jk?
Both kits cost around the same and I was just looking for some input or preferences between the 2.
http://www.ststurbo.com/jeep_wrangler
http://www.RIPPMODS.COM/2007_2010_Je...2-sds-stg2.htm
This is just my opinion.........
Turbos are definitely the way to go for a power adder BUT in a JK application I would be afraid to have that expensive turbo and piping underneath my Jeep. I would worry about pinching a pipe, crushing the turbo, or even getting mud and water in or on the turbo unit. If it was an engine mounted turbo kit It would be a different story.
The RIPP blower kit is the one I would chose for a JK....Engine mounted and out of the way of rocks, salt, mud, water, etc.
If you don't offroad your Jeep for for the Turbo!
Sponsoring Manufacturer
We ask simply - why would you want the main air inlet and oil feed/return lines under your Jeep? poor design in our opinion - Jeeps go off road - That turbo is in a weak spot...
RIPPTECH
The advantage to your blower is pretty much instant power/ boost...turbos have lag.
Op...coming from someone who has a stock motor, no turbo, no blower, why would you want to turbo a jk? Just like rippmods said oil return line, turbo, plumbing, all that stuff hindering ground clearance and a turbo won't give you any more crawling/off road power, unless you strictly run in the sand or somewhere where your going to be In high rpm constantly, Plus trying to battle all the heat soak.
I'm not trying to start a flame war, between turbos and superchargers but I would go with the ripp for a million reasons over the turbo setup but the 1 important thing...look at how often ripp is up here on the forum helping folks whether they have purchased from them or not...imo ripps customer service is awesome and when I eventually have the cash ripp is who will get my business.
Good points everyone! I completely forgot the turbo was under it. Not the greatest of ideas unless a skid and splash shield was made. Hey ripp, would there be a forum special by chance?
Turbo for racing, SC for low end instant power. Only issue is heat. SC must have an oil cooler. My 01 Eaton SC Nissan Frontier was great to drive when the engine was cool, once hot there was no power, I couldnt even do brake stands anymore!
