Thinking of installing Headlight Washers. Has any one done this?
Old Dec 13, 2016 | 08:52 AM
JeeP_MarK's Avatar
Default Thinking of installing Headlight Washers. Has any one done this?
So after that first snow fall this season, I'm consatntly cleaning the dry salt stains on my new led headlamps . Has any one added headlight washers to there existing system or added one of these kits from eBay.
eBay. http://m.ebay.com/itm/291749447065
Looks like the nozzles would fit perfect on the bottom of the light wells and I might be able to tap into the rear washer circuit to triger the pump from its factory switch so when the rear washer is used the lights washers go off at the same time. Only real issue I see is placement of second washer bottle or if I can use just the factory bottle for both. Any help or ideas would be awsome
