towing capacity
How big a travel trailer do you all think I can tow with an unlimited, auto, with 3:73 gear ratio? I dont want a pop up. Anyone with a 20 footer or close that can give some insight?
Well, here is the max the Jeep folks think you should tow, which I'm sure you already know...
I have the same setup as you, and tow an 18' ski boat regularly. It's right at 3500 lbs, possibly a bit more with a full tank and gear. No power, of course, but no problems towing it. I imagine the aerodynamics of a travel trailer would be different than a boat, so can't say what affect that may have. But as long as it's not too heavy, too huge, and has brakes, you should be fine.
With 3.73 Axle Ratio and Trailer Tow Group You Can Tow 3500 lbs
I am offshore at work so I can't get any real details at the moment. My neighbor has a Durango and bought a camper. It is full height but the beds pop out at the ends to save weight. It is designed for people with smaller SUVs that don't want pop ups.
I am also looking at towable but our limited towing capacity does make it difficult. Here is a link you may be interested in. I'm not too fond of the soft sided pop up but this may be an option. http://www.chaletrv.com/chal_trailers.htm
Or this http://www.forestriverinc.com/nd/def...e=rpod&nav=rec
Does your towing capacity change as you add a lift and larger tires? Currently we're running a 6" lift with 37's. Still have the 4.10's in front and rear. Dont want to go w/ a popup but dont want to over do it on a big travel trailer.
Good Luck and Enjoy...
7-pin wiring plug mounted in rear bumper:
I don't know how exactly to re-figure the tow capacity for tires size changes but I would think it would have to change as you are losing power with the bigger tires unless you re-gear. I noticed a difference in power even going to 33's when towing my camper and 4.10's.
Hey, go over to RV.NET, over there you will find lots of info on trailers and towing,
I pull a 5x8 enclosed trailer, I can pull it in overdrive, I don't think I would want to be pulling a travel trailer very far, they are nice though.
