Transfer case fluid change
Here's a good write up: MAINTENANCE : Jeep JK Wrangler NV-241 / NV-241OR Transfer Case Service
Changing the manual transmission fluid is a pain. And, FYI, unless you've driven your '13 JK a lot, or it's been contaminated during river fords (easily checked by dipping your finger into the fill port), you probably don't need to. If you decide to, do be very careful how much torque you put on the drain plug. Too much and you'll crack the rear extension housing. It's a very expensive repair. Don't ask me how I know.
Does this sounds about right?
