Transfer case fluid change
I used those write ups as well. Very helpful. I the manual transmission write up Eddie shows how to make a tool from a coupling. FWIW I did this so there was no cutting and grinding needed...
Attachment 614421
Only a couple bucks at lowes
Attachment 614421
The only thing on my mind was your comment about damaging the transmissions rear extension housing.
Mine went "pop" as a friend was using the "gutentight" method. I had told him I had a problem in the past with seepage, so he was trying to prevent that. $2500 later I had a new trans (and I get dealer's price on parts). Just use caution. It is a pipe thread--the fit is tapered, so you are pushing out on the hole the tighter you screw it in. Better it leak slightly than you crack the housing. Just go back and tighten a tad more if it does. And we used a ratcheting wrench on a short piece of Allen wrench I cut off to manipulate the plug.
I used Amsoil synchromesh for the transmission (not really an Amsoil fan, I know it's good but don't use it often) based on the forum recommendations and now the shifting is so smooth, yesterday I tried to put it in reverse twice while going for 6th on the highway. I've driven manual transmission cars for 24 years.
I'm impressed. I would recommend Amsoil based on my experience especially for transmission and transfer case where it's replaced every 3-4 years.
Changing the manual transmission fluid is a pain. And, FYI, unless you've driven your '13 JK a lot, or it's been contaminated during river fords (easily checked by dipping your finger into the fill port), you probably don't need to. If you decide to, do be very careful how much torque you put on the drain plug. Too much and you'll crack the rear extension housing. It's a very expensive repair. Don't ask me how I know.
So far I've only used royal purple in both transmission and transfer case. Transfer case doesn't feel much different. Transmission, a little better. Will be trying Redline next, just to be sure it feels as good as it's gonna get.
