Water leak problem
Old 04-15-2008, 12:53 AM
jeepinfrance's Avatar
Default Water leak problem
Hello, actuelement on a french forum (http://wrangler2007.aceboard.fr) we have several landlord on what a problem for jk equipped with hardtop, When it rains, water enters the car in passing between the top door Before and hard-top.
Have you already encountered this problem? If so is there any solutions thanks in advance
Last edited by HappyCurmudgeon; 04-15-2008 at 06:10 AM. Reason: removed direct link
Old 04-15-2008, 05:41 AM
only_in_my_jeep's Avatar
Aside from removing and replacing the panels which sometimes works there is a TSB (dealer service note) that tells them how to diagnose this problem and to replace the top seals if needed. I am not sure how it works over there but I would call the dealer if the simple remove and re-install does not work.
Last edited by HappyCurmudgeon; 04-15-2008 at 06:11 AM. Reason: removed direct link
Old 04-16-2008, 01:21 AM
Hi, I find the bst, thank you
Quick Reply: Water leak problem
