What Has Changed?
I have heard of the inside door panels being new and i think something about a new instrument cluster but and not sure any thing else that anyone one know of that has changed just wondering.
The nose had to be stretched slightly to fit that big diesel in there, and the hood center was raised and side vents added to allow air flow into the turbo. (kinda like cowl induction, but not quite) The interior of the doors was changed to allow the gullwing feature to operate correctly. Mopar has also introduced an easy door removal system. Simply open them in the garage, and back out, they pop right off & the rearview mirror dimples will be of little concern. They also released an in garage storage system for the doors if you choose not to use the easy removal system, simply open the doors until they contact the ceiling in the gull wing configuration, and use a few drywall screws to attach them to the ceiling, then pull the pins out & you are all set. This also allows use of the integrated jack feature. After screwing the doors to the ceiling, if you simply close them, it will lift the jeep 3-5 ft off the ground for easy lift installation & tire rotation maintenance.
Oh, and aparently they stopped putting plugs over the armrest screw holes.
