What is with this weird towing harness???
Old Apr 14, 2007 | 11:31 AM
wayoflifette's Avatar
JK-Forum Founder
I'm pretty sure this has been talked about a lot in the electronics section. Here are a couple threads that seems pretty detailed:
https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/wiring-tail-lights-towing-2000/
https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/trailer-wiring-harness-954/
Hope that helps!
Old Apr 14, 2007 | 12:23 PM
Rubimon's Avatar
Sounds like you also need some slack in your wires. When I tow a trailer there is enough extra wire to angle anywhere, sort of like the safety chains.
Old Apr 14, 2007 | 05:47 PM
Cruiser's Avatar
How big is the trailer? Just watch the weight, these thing arent meant for heavy trailers. The 4 pins are standard and yes as stated above you need a controller for electric brakes,, If the trailer is big enough to really need the brakes make sure it isnt too big for the jk,,,
Steve
Old Apr 14, 2007 | 06:14 PM
deadspot's Avatar
ditto - you can get an adapter to 7-pin but it won't operate the brakes. Search for other threads about adding the 7-pin - there are a few addressing the same question.
