Your opinion on my MILD suspension build.
Since I'm getting 33's installed tomorrow, I'm looking at minor lifts. I've searched and searched and researched on here day after day and have come to this conclusion of parts:
Currie RockJock Front Track Bar Relocation Kit (weld in)
Currie RockJock Rear Track Bar Relocation Kit (weld in)
Full Traction Adjustable Front Track Bar
Full Traction Adjustable Rear Track Bar
TeraFlex 2.5" BB w/ shock adapters (soon to upgrade to better/longer shocks)
Skyjacker 3/4" Front Spacers (to yield 3.25" and be level/correct factory rake)
JKS Quicker Adjustable Swaybar Disconnects
What do you guys think? When it's all said and done, it'll EASILY clear 33's with no rubbing on turns nor articulated. Plus, stronger welded in supports for the track bar brackets (which we all see have failed NUMEROUS times). And, could go even higher with the adj. track bars and adj. swaybar links if I ever want to.
Anything you'd edit or add?
Your opinions greatly appreciated.
Advice
A little at a time. I wouldn't weld anything in quite yet. Try out the track bars first they normally fix most steering issues not all but most. With track bars you wouldn't need the relocation brackets. I think you can run 33's on the stock suspension. Most peolpe say you don't need trackbars with the Tera Flex 2.5 I researched for months before i got mine stuff. Check out the "write ups", and search more threads that helped me a lot. Lots of great advice on here already, you just got to dig a little.
He's right
But a bunch of people have torn off their track bar FACTORY brackets with a minimal BB and some even while driving normally down the road. Don't want that to happen to me...
I believe the brackets that have broken were the result of the axle mounted relocation brackets, I don't think anyone has had a failure with the track bars mounted in the stock location. maybe someone else might have a little more info.
Whelerbob
Whelerbob
I don't think track bars will be much of a problem with only 2.5 inches, but I could be wrong there.
Are you going to be wheeling?
I am a fan of springs rather than spacers, unless you plan on not doing any wheeling at all. I have had both and much prefer springs.
Since your going all out, why not go to a 4 inch set up. I have 3 inch Black Diamond springs that gave me a measured 4 inches of lift. Track bar adjusters, etc and off I go. Looks awesome and performs awesome, and the ride is fantastic wir Rahcno shocks.
New springs are not that much more. I bought all my stuff seperate. No kits. Around $500 for the whole thing. 10,000 miles now and very happy.
Which Rancho shocks?
Which Rancho shocks are you using with your BD 3'' lift??
Did you get the flex control arms too?
Have you had any OEM drive shaft problems??
I want to run 285 70 17 KM2's ( 33 inches )
Got any more pic of your rig?????
Thanks ! BWR
Definitely going to be wheeling. Not only a street vehicle. Won't be lifting it if I wasn't going to wheel it.
The MAIN reason I didn't want to exceed 3" was for the sole fact that I read about a lot of driveline issues and driveshafts failing because of the 3"+ lifts. Didn't want to go "all out" and do a 3"+, new driveshafts, etc.etc.etc.
For that much lift get the track bars but not the brackets. If you were going with more lift then I would recommend getting Curries brackets to go along with the track bars. Currie makes great stuff for sure and I can tell you their brackets are very beefy!
