2.5" Teraflex Budget Boost on stock tires/wheels
Old Aug 4, 2014 | 07:20 AM
Dbmoorejr's Avatar
Here is mine. Now has a three inch lift but this was budget boost pic.
Sent using smoke signals
Old Aug 4, 2014 | 08:50 AM
Stubicon's Avatar
Thanks. Did you run the stock shocks with extensions?
Old Aug 5, 2014 | 03:37 AM
hellphenix's Avatar
If I put rubi shocks and spring in, it will lift my jku sahara? 2014
Old Aug 5, 2014 | 04:05 AM
Stubicon's Avatar
^^ you should start your own thread as this one is dealing with the Teraflex budget boost.
Old Aug 5, 2014 | 02:22 PM
hellphenix's Avatar
Your rite sorry. I have the bb but that way raises sum questions.
Old Aug 5, 2014 | 02:31 PM
Dbmoorejr's Avatar
I just ran stock shocks. Never had problems and knew I was changing it later. I had some pretty bad wear on front tires and didn't keep it for that reason. In my opinion, put the 285s on it and save to do a proper lift. You can find good used ones on here every so often. There are people who have said they didn't have bad tire wear but mine stopped as soon as I lifted it basically the same amount but with lower control arms. Or you might be able to find a set of adjustable control arms for budget lift.
