Tire Carriers
Tire Carriers
Just bought a set of 35"s w/ 20"rims, need to install a tire carrier....so I'm told. Lots of options out there, none are cheap. I am leaning toward an aluminum frame to keep weight down. Looking for any advice on what to pick up. Ok in spending more, but needs to be worth it. Any help would be appreciated.
I'd stick with the type that replace the hinges like above, and I'd stick with a name brand unit like Tearflex (some will debate this brand but they designed that carrier and everyone else copied it), Metalcloak has one similar, or the MORryde carrier that is a bit different design but also works well. I'd steer away from the cheaper knockoffs like Smittybilt, Rugged Ridge, etc for this particular item, just my opinion though.
The cheapest option is to do away with the carrier altogether and have a clean rear end. You're carrying a lot of weight back there for looks with a tire that will likely never be needed while on the road. For wheeling purposes, you could always truck a spare along in the back of the jeep if needed. Unless I'm going to do some aggressive things a good ways from home I don't worry about a spare myself.
I am in the same line of thinking as resharp. I like the clean rear end with nothing there. When I go wheeling, I’ve been in places where the spare tire could have ripped off my tailgate if I had the tire there. I almost ripped off my hilift jack mount back there so I don’t even keep that there anymore. I stuff the hilift under the rear seat, it’s solid there and won’t be a projectile if I hit something. I can fit my 37x12.5 spare, 20lb co2 tank, and a box for parts and tools in the back. It’s a tight fit but I get it all there for the trail runs. For daily driving, no need to carry a spare tire.
This was before I removed my hilift but it shows a cleaner back end.
I wish I had posted this prior to my rim / tire purchase...… Going light seems to make sense for the obvious reasons ($$, clean look, less weight). I didn't even give it a thought until this thread. Unfortunately, that ship has set sail. The Smittybuilt was the direction I was headed, now I'm leaning toward the Teraflex. Thanks for the feedback and insight everyone, appreciated!
Resharp, thanks for the feedback since I started this build. Very happy with the MC Gamechanger you recommended, glad I went in that direction!
Since you mentioned Smittybilt, I'd tell you I think there are some things that are perfectly fine that they make. Bumpers are basic items, and I have one of their X20 winches that has treated me perfectly fine for 6 years, but for this application in general I would not skimp if you are indeed going with a carrier.
I've considered not running a spare for a while now. I've had one flat in my 9 years with the Jeep and I had to have someone deliver a jack and tools to change it out on the side of the road. That was the 5th puncture in that tire before one actually let the air out. The spare was certainly handy to have then, but I could almost as easily have pulled the wheel, gotten the tire patched, and mounted it back up. On the two door there's no room to throw a spare in the back for a day wheeling so for now mine is staying on the tailgate.
I had a screw in my left rear tire day before yesterday, probably only 5 k miles on a set of new duratrac’s just a few months old, road hazard replaced the tire, but proof to me a spare is a good thing to have, I don’t like even just going to town and not having a spare
