Sponsored by:
Sponsored by:
TPMS Retrain????
Old 01-03-2019, 08:28 AM
rock7174's Avatar
Default TPMS Retrain????
I have a 2016 JKU with aftermarket fuel wheels with 35's. The previous owner had shut off tpms with a Procal. I turned it back on and none of the sensors will sync with the TPMS system. I dismounted the wheel and found they are Autel 433hz sensors. I have a scan tool that will tell me if sensor is active but won't program the sensor. The sensors are active, but my question is do I have to take it somewhere to have the TPMS retrained for the new sensor specific ID's? These won't "self learn" without being programmed correct?
Old 01-03-2019, 09:24 AM
jadmt's Avatar
not familiar with Autel sensors but OEM sensors which are Schrader self learn after a few miles at above 15mph. I have swapped several times over the years and the schraders have always started working fairly quickly.
Old 01-03-2019, 09:27 AM
jadmt's Avatar
just looked up autel sensors and looks like you need a scanner to program them.
Old 01-03-2019, 09:54 AM
ronjenx's Avatar
Ask a tire shop what they would charge to program your sensors. It may be cheaper than the dealer.
Old 01-03-2019, 12:18 PM
rock7174's Avatar
will do thanks!
Quick Reply: TPMS Retrain????
