Yet another tire size question
I haven't been in the Jeep scene since I flipped my 1972 CJ-5 end over end 3x. We turned it into a swamp buggy and later gave it to a buddy.
Anyway, I just picked up a 2017 JKU Big Bear Package for the wife to daily drive. It won't ever see serious off roading. I may be a little pre-mature, since the Jeep only has 2500 miles on it, but I'm researching options for new tires. I did buy new wheels and tires and 4.10 gears for the brand new Mustang I got her in 2013. I had the new hoops and gears before the new car even arrived. - so I do off the wall things....
The Jeep is completely stock (I did throw on some steps for my 5'4" wife) with the 17x7.5 wheels and 265/70/17 K02's with 3.73 gears. I don't want to replace the wheels, nor will I run spacers.
What would the group suggest as the largest tire I could run? What is the smallest lift I could put on it to gain a bit of clearance while needing the least amount of other modifications?
Since you want to keep the OEM wheels but don't want to run wheel spacers, I'd just add a leveling kit. Maybe go up to a 285/70-17 tire but you'll have to decide if that's enough difference to justify the cost.
I've had the 265 and the 285's in stock configuration. The 265's weren't an issue and that's where I got my best gas mileage. The 285's do rub the sway bar at full lock, like when you're cutting in you to that last parking spot or doing a super tight U turn.
