$19 Reverse Light Solution!
Went to purchase rock lights from Walmart yesterday and noticed a few other lights they had in stock. I read the Platinum Burner lights were very bright and were super cheap so I decided to buy a set of 2"x4" along with my two sets of smaller rock lights. It came to $60, not too bad! Comes with all the necessary wiring, switches, and fuses.
Here is the box for the 2"x4":
After re-sealing all seams with silicone, I pre-drilled a few holes and then installed the brackets with sheet metal screws (the ones supplied are not strong enough to tap into the chassis)
Lights installed:
They're not wired yet, I will post when they are along with a review on how I like them.
And here are the rock lights to be installed sooooon! I covered all seams with silicone.
Lights installed:
Finally got around to wiring up my lights this weekend. They work great at night, wayyy brighter than I expected. These can also be flipped around facing forward for a 'rock light' effect.
In all spent $19 + $8 for a new switch. Installing lights and running wires took a total of 1 hour 15 minutes, taking my time.
Real easy to do, great weekend project.
Sorry for the crappy phone pics in advance...
Installed rock lights yesterday in front & rear wheel wells. I turned the reverse lights to face the underside of the rig. Very satisfied with the build. $60 for lights, $20 for switches, $12 for beer, and about 4 hours.
There's one more check on the list... Next is the 1.25" RC body lift on Saturday!
