2012 rubi' locker modification
Old Apr 19, 2012 | 12:57 PM
BIGNICK's Avatar
Default 2012 rubi' locker modification w/ pics and steps
i completed the locker mod on my 12' rubi'. ive written detailed steps followed by pics.
-remove battery ( connect backup power so u wont lose radio)
-locate and remove relays off the bracket
-relays consist of 4 wires each ( 3 yellow wires and purple wire)
- relay w/ purple wire w/ green stripe = rear locker
- relay w/ purple wire w/ blue stripe = front locker
-connect new wire w/ existing relay wire while wire connector for each relay
-i ran the wire along the firewall and threw a hole located near the brake master cylinder
-pop of the side cover a pull wires threw slowly
-i gorunded the wires off a bolt with a ring connector
-install your switches were you please and put back removed items
-i customly cut my offroad panel for my switches. i off-centered them from front to back to now which was which. unfortunatley while tightening the switches i snaped the panel so ill have to fix that later but the switches are still operating.
ID:	306609   Click image for larger version
ID:	306610   Click image for larger version
ID:	306611   Click image for larger version
ID:	306612   Click image for larger version
Old Apr 19, 2012 | 01:14 PM
BIGNICK's Avatar
some more pictures
ID:	306614   Click image for larger version
ID:	306615   Click image for larger version
ID:	306616   Click image for larger version
ID:	306617   Click image for larger version
Old Apr 19, 2012 | 01:15 PM
BIGNICK's Avatar
last of the pictures
ID:	306619   Click image for larger version
ID:	306620   Click image for larger version
ID:	306621   Click image for larger version
ID:	306622   Click image for larger version
Old Apr 19, 2012 | 01:43 PM
Delux2769's Avatar
Awesome write up, I had no idea where the relays were until I noticed you pictures showing them.
Old Apr 19, 2012 | 06:07 PM
Extremehabit's Avatar
that's pretty clever.
ps: that's a lot of air fresheners!
Old Jun 29, 2012 | 08:30 PM
crashthings's Avatar
What does this MOD do?
Thanks
Old Jun 29, 2012 | 08:38 PM
leonescomp's Avatar
Thanks
allows selection of front and rear locker independent of each other.
Old Jun 30, 2012 | 04:26 AM
greggnj's Avatar
And, if I'm not mistaken, in 4 hi
Old Jun 30, 2012 | 01:18 PM
BIGNICK's Avatar
Yes front and rear locker in 4hi and and rear locker in 2hi
Old Jun 30, 2012 | 01:22 PM
aldaman's Avatar
Great write up, thanks 4 sharing
