Air Dam Pushpin Removal
I found a good way to get the Air Dam pushpins out without messing them up, simply use a 4 way tire air valve remover. Screw the pointed end counter clockwise into the pushpin until it catches then gently pull out on it a little as you continue to unscrew it.
