Air Horn
Thanks everyone for the help. However, last night while sitting on the couch I was browsing through my Quadratec catalog and noticed they have a complete set up from Kleinn. This setup comes with horns, on-board air system, and everything else I need to get it done. Has anybody used this set-up? Sounds like a no-brainer to me but wanted some more input before I pull the trigger.
Kleinn Air Horns JeepKit-1 Black Complete Bolt-On Dual Air Horn Kit for Jeep Wrangler https://www.amazon.com/dp/B00EVQHQS8..._3Q89vbAJECZDF
In my opinion the basic hornblaster Shocker horn is the best kit you can get for the price.
https://www.hornblasters.com/product...FQtFaQodRakFEA
I considered external compressor air horns, then found a simpler and quite effective solution, by combining two STEBEL air horns (integral air pressure).
One is a single low tone (300Hz) Nautilus, the other is a dual tone Nautilus.
The combination with the low tone makes them pretty loud and penetrating.
like all air horns, they should be installed so water doesn't get in.
For cheaper air horns that don't use stainless steel diaphragms water is a big issue. But with a quality train horn getting water in them doesn't hurt. Mounting them in a way that the water can drain out is the important thing.
That's what I meant. Facing somewhat downwards prevents water/dirt from reaching the diaphragm. The best diaphragm would sound hoarse if muddy dirt gets to it.
