Any bumpers out there with a blue ox tow bar ?
Old Aug 8, 2014 | 06:35 AM
Tc1316's Avatar
Default Any bumpers out there with a blue ox tow bar ?
I have a 12 jk that we use to tow behind the motorhome , using the blue ox system and looking to put a steelie up front instead of the stock . Anybody have a bumper that would work with it ?
Old Aug 11, 2014 | 12:24 PM
newroswell's Avatar
Based on a tip from another member, I called to order my LoD Offroad mid-width, and they welded on the tabs while building the bumper and before the powder coating process. Turned out perfect.
Old Aug 12, 2014 | 03:36 PM
redridge's Avatar
Instead of the bumper, I use a Currie skidplate with blu ox tabs. You should be able to use after market bumpers over this skid plate, but you have to make sure from the manufacturers that it will work with it....
Old Aug 12, 2014 | 04:54 PM
rangercliff's Avatar
Default blue ox alladin
ID:	570874Click image for larger version
ID:	570875Click image for larger version
e-bumper rock crawler with blue-ox mounts, 1 bolt on each mount is through frame.
Old Aug 24, 2014 | 03:26 PM
Tc1316's Avatar
Thank y'all for the help !!! four wheel parts wasn't much of a help !!
Old Aug 31, 2014 | 06:59 AM
s2kdrifter's Avatar
I run the Currie skid plate with a blue ox aventa tow bar. Works great!
Old Feb 12, 2015 | 10:36 AM
mikechilcott's Avatar
Default Blue Ox Tow bar with a Barricade bumper?
I have the Barricade trail Force HD Bumper. Anyone know if it will work with the Blue Ox Tow bar?
Thanks - Mike
Old Feb 12, 2015 | 10:46 AM
Rubi-josh's Avatar
Mine is mounted to the frame below my ARB deluxe bumper.
My father in laws (Dune Sahara) are mounted to where the tow hooks go on his Smittybilt.
Name:	Jeep 35s 2.jpg
ID:	596500   Click image for larger version
ID:	596501   Click image for larger version
Old Feb 18, 2015 | 05:51 AM
Boostable's Avatar
Late to the party, but you should check out the RockHard4x4 front bumper. I purchased it specifically as the tow points mount directly to the frame. Works and looks great!!
Old Feb 18, 2015 | 11:10 AM
s2kdrifter's Avatar
That looks great! I like that you are running the hex head bolts for both sets..
