Bofer84's Locker Mod Write-up
Old May 31, 2008 | 05:57 PM
  #101
ChewyGranola's Avatar
Originally Posted by 4LO
BTW, has anyone done this WITHOUT removing the battery? Everytime I unplug my battery I have to call Sirius and sit on hold for 20 minutes so they can reactivate my receiver.
Sorry dude, not enough room. Unless you have the hands of a 4 year old...
Your Sirius should not do that... You should get that fixed because it is a major safety thing to disconnect the battery ground anytime you mess with any electrical on the Jeep... Especially when you have airbags and Computer engine controls... An accidental short in something that you are working on could actually deploy the airbags or fry the engine computer.
You could always put some kind of battery backup system in line with your radio to supply 10 mins of power or something like that.
Old May 31, 2008 | 06:07 PM
  #102
Do you have an Spod?
If not, you may be a little confused. Tapping into this wire from a powered switch will power the locker, but you're bypassing the OEM relay. The Spod uses a relay(activated by a switch) to power that wire.
So if you do not have an Spod, and you choose to power that wire, you'll have to run another relay anyway. Otherwise you would be supplying power to the locker from the same source that is supplying power to your switch.
Without the sPod, you have a choice of either splicing into the Yellow wire (with white or orange stripe) and running that to a relay, or splicing into the ground wire with just a simple switch... You dont need a relay for splicing into the ground, because the ground wire is not part of the high amp circuit, its just part of the low amp switched circuit.
In the end, there is more than one way to do it. Some are more complicated than others. If you have an empty sPod switch that you want to use for the locker(s) the simplest way is the one wire splice (per locker) that I mentioned above.
Old May 31, 2008 | 11:07 PM
  #103
Well you have a couple of variables there...
Since we just did the mod for the rear, its hard to compare with the problems that you are having...
A couple of things come to mind...
If you turn off the engine completely and pull the keys, does the front locker light still flash?
Does it flash all of the time when the t-case is in all modes, whether it is locked or not?
If so, it sounds like either something is goofy with the computer, or that the dealer may have done something with the locker...
Do some more troubleshooting, trying different things, and post the results here...
Old Jun 1, 2008 | 12:05 AM
  #104
Does the locker lock when you turn the switch to the on position and unlock when turned off.
Old Jun 1, 2008 | 09:52 AM
  #105
4Lo... Hmm, not sure what to tell you, its definitely acting strangely... Sounds like you may have a problem associate with the dealer work you had done...
Neo, the best advice is just to try to keep it simple... If you really need to have that light come on when you hit the switch, then you probably will need to add in an additional relay and do the yellow orange or yellow white wire mod to bypass the relay, or you could still do the ground mod and add in a relay...
If you can do without the light... Stick with the ground mod with a simple switch.
Old Jun 14, 2008 | 04:33 PM
  #106
hurstrescue's Avatar
Great mod and great write up!!
I did this today. I only have the rear locker, but still worked really well
Old Jun 25, 2008 | 10:57 PM
  #107
deconstructionist's Avatar
Hate to momentarily hijack.............. I can only see 1 pic in this entire thread? Anybody know what's up with that? I can see pics on other threads...just not this one.........
Old Jun 28, 2008 | 04:26 AM
  #108
Someone is selling the locker mod on ebay for $9.95....and people are buying it....look at the feedback....
Item number -
290241861768
Old Jul 9, 2008 | 07:24 AM
  #109
badbu79's Avatar
I do not see any pics either
Old Jul 9, 2008 | 07:47 AM
  #110
yeah: still the same for me. Can only see ONE pic in his gallery/album too
