Center dash with Daystar panel rattle fix
I noticed a rattle coming from the center of my dash off and on for a long time. This past Saturday it was particularly annoying, so I decided to look into it.
I first looked at all of the threads on center dash rattling. It looks like there are a number of areas/sounds that are occurring.
I decided to start with something easy, like remove my Daystar panel and see if I could see any problems.
I noticed two things. My compass was loose, and the plastic cable tie down appeared to be too big (because of the storage areas on the Daystar panel). I tightened the compass and put a piece of tape between the plastic standoff and my radio and took it out for a listen. The rattling was greatly reduced so I deiced to make the following changes.
Here’s the offending plastic cable tie down:
I cut it off:
And added some extra tape to my wires, and held them down with a new tie wrap through the hole:
I also added some tape to the back of the compass module:
Compass module re-installed:
After making these two changes I took it out on the local streets, and the rattle is now gone. I won’t be able to take it out on the trail for another week or so, but I think that plastic cable tie down was the culprit.
I decided to start with something easy, like remove my Daystar panel and see if I could see any problems.I noticed two things. My compass was loose, and the plastic cable tie down appeared to be too big (because of the storage areas on the Daystar panel). I tightened the compass and put a piece of tape between the plastic standoff and my radio and took it out for a listen. The rattling was greatly reduced so I deiced to make the following changes.
I cut it off:
