Chopping a stock bumper?
My first pass was a straight cut with a Sawzall, no dressup.
Second pass was trimming down farther and dressing the ends closed. I used a pistol-grip soldering iron to achieve the proper "weld" of the plastic ends. (propane torch accomplished little more than melting on thin walls of LH side -the fugly you can see on the LH side was from torch, then recovering with soldering iron)
Others have complained of body filler or weld not standing up. Mine is still holding tight. It looks about as good as plastic can, since my ultimate goal is to end up with LōD on my nose.
stubbified!
Its EASY, the hardest part is taking the saw to your new jeep!!! I chopped my front and rear off, it looks a hell of alot better and totally worth the whole moment of the initial cut!!!!!
Check out my gallery, i will be posting pictures of the rear "finished product" On the front i am waiting to get a filler for a more cleaner look.
