Daystar 1" body lift
Old 07-06-2012, 07:47 PM
sprunky's Avatar
Default Daystar 1" body lift
Hey everyone. I just installed the Daystar 1" body lift on my 2012 JKU manual. Does anyone know how to get to the shift boot on the new 2012?? I can't shift to 2, 4, 6 or Reverse. Your help is appreciated!!
Old 07-08-2012, 04:47 PM
tweeder448's Avatar
I saw a shifter extension somewhere but honestly I do not remember where. Fortec maybe... I took everything off and cut out some of the body. However I do not recommend that since it does let in all the heat coming from the exaust and undercarriage. I would look for the bolt in extension because it would be a lot easier and is engineered for this problem.
Old 07-09-2012, 07:36 AM
sprunky's Avatar
Thanks but I had to cut into it since I needed to drive it You're right it does let in ALOT of heat. oh well! Maybe I'll try and remedy it later with the extension and a new boot
It looks like Rough Country makes it. Product # 92RC60200
Old 07-09-2012, 07:39 AM
sprunky's Avatar
Originally Posted by Siccjeep
Check ebay for jk shifter extension. How long did it take you're install the body lift? Any problems?
It only took me about and hour and half to do. It was pretty easy. It says that the 4 door has 12 body mounts but my 2012 JKU only has 10. You can see where the other two go in front of the back coils but there was nothing there.
Old 07-09-2012, 08:19 AM
Prokay22's Avatar
Do you have pics?
Old 07-17-2012, 07:47 PM
Rock907's Avatar
Originally Posted by Prokay22
Do you have pics?
Here is the Daystar 1" body lift. Before and after, notice the difference between top of front bumper and bottom of grill
ID:	342449   Click image for larger version
ID:	342450   Click image for larger version
ID:	342451   Click image for larger version
Old 07-17-2012, 08:30 PM
Delux2769's Avatar
I actually like the look a lot more with a 1" BL. I'm looking to do it once I cone across a good enough deal on a BL.
Old 07-19-2012, 10:43 PM
Rock907's Avatar
1" is definitely noticeable in person. If I remember correctly I purchased the Daystar through quadratec for 100 bucks.
Old 07-23-2012, 02:04 AM
RedRockJeeper's Avatar
Yeah nice job it is easy. I purchased the 2 3/4" combo lift which comes with the body lift and a 1 3/4" coil spacer lift and shocks.
The body lift was super easy and I am gonna TRY to get the spacer lift and the Northridge hardware on this weekend.
Old 07-23-2012, 06:54 PM
Devildoc's Avatar
I already have the1 3/4 spacer lift. I would love to see pics when you get your spacers done.
Quick Reply: Daystar 1" body lift
