Disable/Enable feature codes/sequences
#101
I can not get the ESP to turn off on my 2011!! Do you guys do it with it running or just the key in the on position? Also i might of missed it but is there a way to turn off the tire pressure light?
#102
Originally Posted by FlameRedJK
Actually learned this from a friend with a CJ7?? But in the 2012 if you just hold down the ESP button for 30 seconds or so it will disable the ESP...has to be redone every time you turn the engine off and back on but very handy
#103
Originally Posted by jkrubcon
How is this any different than just tapping the button once and turning it off?
I would be curious to know more about it myself though, as far as the difference
#105
There is an explanation on the cd manual, basically just pushing the button once delays the traction control but still has it activated, if in 4 hi you can completely disable this by pressing and holding for 7 sec. But it resets if you go into 2 hi or turn off the jeep. Doing the steering wheel dance turns it off in all ranges and stays off till you do the dance again. If you drive on snow you can really notice the differences
#106
#107
TPMS Disable??
How do you disable the Tire pressure monitoring system. I put 35's and XD wheels on my 2010 Rubi and my light comes on and chimes everytime i start the engine.
#108
#109
I tried that with my Superchips but it only let me adjust the pressure alarm. I turned it down to the lowest pressure witch is 26psi, but the light and chime stil comes on everytime i start the engine.
#110
Make sure all your tires are over 26psi, including the spare. If the chime & indicator still comes on, then there's something else wrong.
