Disable/Enable feature codes/sequences
#91
Yes the only downside would be your battery would drain just alittle faster but if you have the stock stereo and nothing else on then you can run it for awhile. Just make sure you start it up every once and awhile to charge the battery.
#95
Originally Posted by ColeRedRubi
When I do the ESP off code it turns off the ESP but dings twice every time I stop. Ideas? ESP off is waaay better on the dirt!
#96
Originally Posted by Wolfesneck
I used to have a delay on my headlights but now I do not. Any sequence on resoring this feature?
#97
You have two options first turn the key to the "on" position the the dinging stops in a few secs, the second option is unplug the wiring harness for the doors you want to keep open. When you unplug the doors the sensors are disabled and no dings come from the jeep. Enjoy the tunes!!
#100
Actually learned this from a friend with a CJ7?? But in the 2012 if you just hold down the ESP button for 30 seconds or so it will disable the ESP...has to be redone every time you turn the engine off and back on but very handy
