DIY Sway Bar Holder (Manual Disconnects)
I haven't seen this posted before. I stole the idea from one of the North Texas guys.
You need:
1-1/2 inch diameter wood dowel (6 to 8 inches long)
#2 Pipe Clamp (find in the electrical aisle of Home Depot)
Zip Tie
I had to buy a 4-ft piece of dowel, so I had enough left over to give out to the other 4 guys on our trip to Barnwell last weekend.
-Cut the dowel to about 8 inches
-Install the clamp on one side.
-Slide dowel into the frame tube
-Zip-tie your sway bar in a 'neutral' position with the sway link zip-tied to the sway bar. I found out the hard way that you will rub the link if you tie the sway bar in the "up" position.
Here's the overall view.
Notice there's a little hole to run the tie through.
The frame hole into which you insert the dowel.
Sway Bar zip-tied in place with the link zip tied to it. Note the "Neutral" position of the sway bar to avoid rubbing.
You need:
Zip Tie
That's not a bad idea! Way to be innovative. This will work while you're out on the trail, it doesn't need to be anything special. I think wood is a great idea. Depending on what you wheel in, it'll eventually rot, but I think that'll take a while before that happens.
