Fuel Tube (Filler Tube) Replacement for Jeep JK
Old Sep 2, 2016 | 12:21 PM
XinnKoda's Avatar
Post Fuel Tube (Filler Tube) Replacement for Jeep JK
I have been getting spit back when I fill my Jeep so I took it to the dealership to cash in on the "Lifetime Warranty" replacement for the fill tube. My Jeep originally came from Canada and when the dealership saw that, they denied me coverage because of reasons. It's my understanding that if they were to do warranty work on a Jeep originating from Canada, the Earth would rotate off of it's axis and plummet into the Sun. So I decided I would replace the part myself.
This is an extremely easy repair to do. So easy in fact, I haven't found any write ups on it on the web. But I figured I would do one for the not-so-mechanically inclined DIYer.
Before you begin... your Jeep is most likely covered under the "Lifetime Warranty Extension". This is not the same thing as the Lifetime warranty offered for new Jeep owners. Even if you did not buy the Jeep new, you should be covered unless certain circumstances (like mine) are present. So, check with your dealership first to see if they'll do this for free. Here is the TSB (Technical Service Bulletin) for the repair:
Time: Less than 20 minutes.
Cost: Approximately 40 dollars if you buy the parts online.
Difficulty: Very Easy
What you'll need... A pair of wire snips, a stubby Phillips screwdriver, 2 zip-ties, and the new fuel fill tube (part number CNNNX321AC). The TSB calls for 2 "tie straps" part number 06016076 but these are simply zip ties.
Place your tools and parts in front of the driver-side rear tire (this will make it easier to grab them).
The part we are replacing sits directly above the rear axle and slightly forward. It runs parallel to the ground and is easiest to access by sliding under the Jeep from the rear bumper. In this picture, you can see the fuel tube, as well as the rear differential. (The fuel tube runs horizontally from the driver side tire to the passenger side tire.)
We need to snip the 2 zip ties holding the main fuel tube to the recovery line. Be careful not to snip the recovery line.
Now we need to loosen the hose clamp that connects the new part to the filler neck. There are 2 clamps that hold the part in. This is the hose clamp on the driver side that needs to be loosened.
Now we need to loosen the hose clamp that connects the new part to the gas tank. This is the hose clamp that connects to the fuel tank and is on the passenger side (relative to the new part). Notice that it is located almost directly above the rear differential.
I chose to remove the fuel tank side first and then slip out the other end that attaches to the filler neck.
Once you get the fill tube off the fuel tank, the other side slips off easily. We are now ready to install the new part! Start by placing the fuel tube in place starting with the driver side (or the side that attaches to the filler neck).
Next, place the other side of the new fuel tube onto the gas tank. Once they are both in place, rotate it back and forth to ensure the hoses are seated onto the surfaces. Tighten down the hose clamps but be careful to not over-tighten the side of the fuel tank. The fuel tank is not metal and you don't want to crank the tank by over tightening.
To finish up the install, we need to replace the 2 zip-ties securing the recovery line onto the new part. There's no need to crank these down, just snug them up enough to stop excessive movement on the recovery line.
And that's it, you're all done. Here is a picture of the old fuel tube.
To ensure this problem never happens again, I suggest selling your Chrysler product and going with something GM made.
Cheers!
Old Sep 3, 2016 | 06:59 AM
karls10jk's Avatar
Very easy fix but that doesn't mean GM is the answer. The prices have been going up on those tubes, they used to be $24.
Old Jan 5, 2019 | 06:48 PM
07bender's Avatar
Angry Fuel Spillage Still using the GM Part
Attachment 655903
Attachment 655892
Attachment 655893
Attachment 655894
Attachment 655895
Attachment 655896
Attachment 655897
Attachment 655898
Attachment 655899
Attachment 655900
Attachment 655901
Attachment 655902
Cheers!
I know this post is for a JK, but my 2007 Wrangler JK has been overflowing for over a year now. Every time i fill up. It only has 84,512 miles on it. So I decided to try the GM part today. No Luck. Still leaks. But I think I see why. On the JK fuel tank where the new GM Tube would fit at the tanks inlet the line is straight (Parallel with the axel but above it of course) instead of angled on the left side like the TJ's setup. I purchased the GM one because the Chrysler replacement was over $300.00. The GM part does work on TJ's, like my 1997 did. Any ideas??
Old Jan 6, 2019 | 03:42 AM
karls10jk's Avatar
Which part number is over $300?? I just Google'd the number above (same one I used in my 2010 with spit back issues) and it's currently $32. I don't have any further issues with the spit back/ over flow except when the pump has shut off and I try to cram a few more clicks in it. So really, not an issue with the part but moreso operator error.
tascaparts.com/oem-parts/mopar-tube-fuel-cnnnx321ac
Old Jan 6, 2019 | 09:41 AM
07bender's Avatar
This part number CNNNX321AA, Chrysler could not verify, So Dallas Chrysler said they have a part that is the same from what the picture showed, but I was so pissed I forgot to get their part number. TY for this link, I just ordered it.
Old Jan 6, 2019 | 09:46 AM
karls10jk's Avatar
Yeah, I didn't bother going to the local dealer when I bought mine, just found the best price online and had it shipped. It's crazy that the dealer can't (or won't) order some parts.
Hopefully you'll have the jeep fixed and back on the road in no time flat. Leave a little slack in the vacuum line that goes to the top of the fuel tank otherwise the brittle plastic may break and you'll end up with an evap code.....ask me how I know.
Old Jan 17, 2019 | 12:45 PM
07bender's Avatar
Default Overflow Fixed!!!
Thank you karls10jk,
I purchased the part from your link: tascaparts.com/oem-parts/mopar-tube-fuel-cnnnx321ac . It took a bit to get here. Installed it last night. After work today I filled up the tank and first time ever, No overflowing. Thank you so much for the help on where to buy the part.
Old Mar 5, 2019 | 07:04 AM
jgaines's Avatar
I've had my 2009 Unlimited since April of 2010. I bought it with 7500 miles on it. I have nearly 180K on it now, which means that I have filled up well over 500 times...and each time, I've had to slow down around 15 gallons and listen closely to the sound of fuel coming up the neck to time a perfect release of the pump handle. After this install, I let her rip. I stood by, cautiously optimistic - like, it being the 4th quarter and the Saints are up by 3 touchdowns (Saints fan here). Most likely, they SHOULD hang on...but after all, they are the Saints. And after all, this is a Jeep. When the pump's handle auto-clicked off without any spit-back, I raised my arms in a "V" and fist pumped to the sky. I'm sure the other patrons had questions, but zero F's were given at that moment. At that moment, I have never been more excited about filling up a vehicle in my life.
In all seriousness - based on 1) time it took 2) ease of access 3) cost of part and 4) benefit gained....this is the greatest thing since penicillin. As far as easy Jeep fixes/benefits gained, I'd say this is #1, and flipping the rear view mirror upside-down is #2. Thank you for the step-by-step too...very easy to follow!
Old Mar 11, 2019 | 08:17 PM
Rednroll's Avatar
Man....just be glad you're not a Lions fan like some of us....this whole thing would have likely fell flat on it's face, snatching defeat from the claws of victory in the closing minutes and you would be currently driving around in your JK with a paper bag with 2 eye cut-outs over your head.
Old Apr 6, 2019 | 10:57 PM
WaterRat72's Avatar
Flipping the rearview mirror upside-down? What am I missing here?
