Garage Door Remote wired switch with relay
Very nice. How are you going to go wireless with all those components?
That's a good question. I will let you know when I figure it out. I've been experimenting with RC circuit boards for a while. I've got a utility truck and I put 12v actuators on all of the tool box doors and made them remotely operated. This will be tougher but doable.
Well good luck with it - Haven't seen anything like it, so it will be very interesting to read your write up when ever you get around to it hint hint.
Hint taken. Ill be sure to do a write up. I like your relay idea. I didn't even think about that. I thought it was a non issue because its usually in the garage. But I have left it outside doorless before. Never gave it second thought. I did worry about someone pushing my winch in button when its already spooled up tight.
Excellent Write up
That is a beautiful job. Have seen other similar mods with individual switches. I like the rocker idea as I too have double garage doors and don't want to lose the ability to open the other door if I need to.
I'm not necessarily worried about the opener not working without power... so I guess I could forgo the steps with the relay and just wire up the rocker switch straight up and get the same results?
Thanks for a nice job
Now I just have to pop off the panel, drill some holes and do a little soldering....
Thanks again!
