Grill Mod
Grill Mod
[IMG][/IMG]
[IMG][/IMG]
I cut a piece of expanded aluminum metal 15" x 28". Primed and painted satin black and then notched out around the retaining clips for the grill, I used self adhesive zip tie blocks and trimmed them to fit between the grill slots. I used 3 on each slot of the grill and 3 on each end, all of them evenly spaced and used black zip ties to secure the grill insert in place.
All the materials came to around $25 or less.
[IMG][/IMG]
I ordered mine through www.mcmaster.com
type in sheet metal
Click "Sheet Metal Products:
Click "Sheets,Bars,Strip, Cubes"
Thats for the sheet- 28.5x14
Part # 7582K12 for the zip tie cubes in black
I used Brake cleaner to clean the grill and black caliper paint to paint it.
Paint first so its ready for install!!
I Took out the 6 plastic screw- did by hand - hint hint
Pulled gently by the blinker- not to hard now its still connected
Pulled red tab out FIRST- then pulled plug out
Pulled bottom out
Have grill ready
Laid all the tie downs - 3 going down and one on each top hole
Zip tied each one using a small screwdriver to help get the tie up
Re Install the grill and Vuala!!
THANKS Ponpeta!!!!!!
type in sheet metal
Pulled bottom out
Have grill ready
I ordered mine through www.mcmaster.com type in sheet metal
Going to paint and install this weekend
Excellent mod and write-up guys! Just did it myself and looks great!
As an fyi to others, you'll notice the grill is slightly bowed out, and when putting the screen insert in, you'll be best off trying to curve the expanded metal 'before' painting and installing -- that is only if you care and want to keep the entire bow in the grill.
As I was moddin' it, I checked a few times from the other side to see how it looked... Since my expanded metal was not curved, I figured it would bend to the grill -- but the grill bent to the metal... It doesn't look bad at all, I'm just a little too anal sometimes. The center sections of the grill are more flat now... Which... if you really think about it... this is two mods in one -- grill insert and grill flattener - like the previous jeeps (although the slant remains)..
