Grill Mod
Old Jul 26, 2010 | 07:17 PM
  #731
fawkes's Avatar
I love cost effective mods, this is very high on my priority list
Old Jul 26, 2010 | 07:54 PM
  #732
kCed's Avatar
where do you guys exactly go to get this expanded metal? ive looked at a couple place locally and couldnt find it...perhaps im not looking at the right places!?
Old Jul 27, 2010 | 03:27 AM
  #733
sn00wman's Avatar
Most of the places you can get it are like metal suppliers...like places that sell the raw materials to make a trailer or a bbq smoker.
try these places and ask where to get it...you only need about a 1/4 sheet but might have to buy a 1/2 sheet these are local to you
Milltown Metal Shop
62001 Road 17W, MB
204-353-2029 204-353-2029
Fax : 204-353-2029
Category: Steel Fabricators
4Silver Winds Metals
204-626-3381 204-626-3381
Category: Steel FabricatorsMap
5Sofelco Enterprises Ltd
204-243-2522 204-243-2522
71089 Road 27W, Poplar Point, MB, R0H0Z0
6Evercare Industries
204-895-9500 204-895-9500
8424 Wilkes Avenue, Headingley, MB, R4H1B8
7G J Vis Enterprises Inc
204-897-6949 204-897-6949
140 Parkland, Oak Bluff, MB, R0G1N0
8Bruder Built Mfg Ltd
204-322-5279 204-322-5279
Old Jul 27, 2010 | 10:31 AM
  #734
GreenJK713's Avatar
Hey guys a lot of the blocks keep coming off. Any suggestions on what type of adhesive to use to keep those zip tie blocks down?
Old Jul 27, 2010 | 10:43 AM
  #735
hx15537's Avatar
A two part epoxy seems to work really well. Just make sure you take the foam adhesive backing off of the tab first.
Old Jul 27, 2010 | 10:45 AM
  #736
hx15537's Avatar
I've it at one or two Home Depots, if you can't find it there you can look online. I got circular punched aluminum from mcmaster.com. It's a little more expensive doing it that way, but you can get something that is really custom.
Old Jul 27, 2010 | 10:47 AM
  #737
rinkishJK's Avatar
your not gonna find it at depot or lowes... u need to find a sheet metal shop or something like that. i went to a sheet metal place. got expanded steel just like in the link pic. cost like 15$ if i remember right.
Old Jul 27, 2010 | 11:08 AM
  #738
Merlin4979's Avatar
Gorilla Glue works like a charm. Soak the blocks in alcohol or Goo-gone to remove the sticky pads before you do the mod, then use the Gorilla. MUCH better.
Old Jul 27, 2010 | 11:11 AM
  #739
GreenJK713's Avatar
Ok I think thats my problem. I had put it on once just using the sticky pads on the bottom of the blocks. Of course those decided to come off (even after cleaning the grill with alcohol). After that I tried the Epoxy but it seemed that only one of the two parts would come out of the tube. After using that they still came off. I'm not sure if its because I only used one part of the epoxy glue or because I left the adhesive pads on the blocks. I will take off the adhesive and reglue it with either the epoxy or gorilla glue and see what happens
Old Jul 27, 2010 | 11:18 AM
  #740
rinkishJK's Avatar
Default Re: Grill Mod
I too had to use gorilla glue to hold the zip tie anchors on. The sticky pads don't hold.
Sent from my Droid
