Hardtop hoist/storage write-up
Old Jul 17, 2008 | 08:59 AM
  #121
WestKySahara's Avatar
Great minds think alike!!!
Old Jul 23, 2008 | 10:25 PM
  #122
YellowToy's Avatar
Actually, I've seen a thread that explained how to install roof rack rails on the top. I was thinking I could do that to haul a canoe & would be able to connect to the towers/rails.
I'm still using straps, but they are a bit of a pain. I may need to make/find the hooks as others have done. But, I can't lift it with my back glass up. So I'll have to come up with something different there.
Originally Posted by JEEPJK
How about attaching some aircraft hooks into the top itself? These loops clip on and off and are used in jetliners - each loop has a rating of 1000lbs if I recall. Iodize the 'channel' or track black, get some aluminum backer countersink it and screw to the top - use the "T" as built here and just hook in the loops..maybe make the "T" into box and have four hooks....with the loops off when the hardtop is on, the 'channel' attached to the roof would not be seen as it is pretty low profile..3/8inch thick...especially with a jeep with a 3inch lift and 35s ...
http://my.project-jk.com/showphoto.php?photo=25476
http://my.project-jk.com/showphoto.php?photo=25475
Old Jul 24, 2008 | 04:59 AM
  #123
christok21's Avatar
Great work. I was wondering though if you knew the actual weight of the 4 door hardtop. I'm in the process of building my own lift and want to make sure it's stong enough.
Old Jul 24, 2008 | 08:54 AM
  #124
bobzinger's Avatar
It's posted on one of the pages in the thread here, but its about 95lbs. of awkward weight.
Old Jul 24, 2008 | 07:20 PM
  #125
TBJK's Avatar
yeah it is really awkward i have pulled mine off by myself...not really sure how i did it but i got it off and back on in the same day. I would guess 95 is about right
Old Aug 2, 2008 | 09:14 AM
  #126
LSU-JK's Avatar
Default awsome ideas,
Bump...Im taking notes and burning up the printer..
Old Aug 2, 2008 | 01:59 PM
  #127
YellowToy's Avatar
If you get up here to Shreveport drop me a line & you can check mine out. I'll probably be helping a friend build his in a couple weeks.
And the weight of the top is 95 lbs. I found it on the Jeep site before.
Old Aug 17, 2008 | 06:24 PM
  #128
sdhexpert's Avatar
Default my installation ....
Thought I'd post my pic's, maybe someone can get some ideas from my install of this great idea. Mine is not as pretty since I used some angle iron I had laying around. But it sure works good. Tractor Supply was a good source for parts.
Old Oct 9, 2008 | 04:27 PM
  #129
doc307's Avatar
I need to do this as well, I guess I will be making a trip to home depot
Old Oct 12, 2008 | 04:41 AM
  #130
LifeTime's Avatar
First, thanks for the write-up and pics, they're a tremendous help. Now for a few questions:
Has anyone had a problem hanging the top with the T-Bar and hooks only (not resting it on a suspended platform)? Can it stay like this for a long period of time (6 months)?
Has anyone built this in a standard 8 foot high garage? If so, how much clearance is under it?
