Hardtop hoist/storage write-up
Great write-up. I've got mine going together now (with an electric winch), just need a few more parts. I'm also working on a storage shelf on a track system so I can move it laterally for various garage needs.
Well the temperature is warming up so it's that time of year to take the hardtop off on my 4door JK Rubicon. My goal was to create a hardtop hoist/storage system that was easy to use and could be done by one person. Here's how it went ...
I used a two step approach first lifting the top up to my garage ceiling using hoist bar and hand winch. Once the top was up to the ceiling I lowered it onto a suspended wood shelf.
Hoist Parts:
10' Channel Strut (Home Depot "SuperStrut" or B-Line B22 Channel; see www.b-line.com for catalog) (qty: 1)
5 hole t-gusset plate (see www.b-line.com for catalog, part #B532 - used to join the two pieces of strut to form the "T") (qty: 1)
Channel nuts/bolts (qty: 9)
Channel end caps (qty: 3)
Channel washers (2-holes qty=3)
Channel washers (1-hole qty=1)
1/2" x 3" eye bolt (qty: 1)
brake winch
3/8" nylon rope (50' length)
2" pulley (block and tackle) (qty: 1)
2" swivel pulley (qty: 1)
quick links (qty: 2)
lag screws (qty: 20 or so)
3/8" square U-bolts (qty: 3)
3/8" vinyl tubing (qty: 2 feet)
36" slotted angle (qty: 2)
foam rubber pipe insulation ( 1 - 7' length)
Hoist Parts:
brake winch
Thanks
Thanks for a great write-up. I just have one question. I went to Fastenal to order the parts and they weren't clear what size U-bolts you used. They have several different combinations of Inside Length (3"-5")/Thread Length (1 1/2" - 5 5/8")/Inside Width (2"-4"). Any idea which size you used?
Thanks
Thanks
Don't Use the hooks that you would store a bike with. I made a top hoist system and the hooks made a nasty gash in the upper corner of the doors on the top.
Any recomendations on a different type of hook, I have the rest of the hoist setup.
Also, any idea where I can get the plastic end caps? Fastenal said they don't have them and Home Depot didn't have them either (according to the guy I talked to).
