Heat transfer
Old Aug 7, 2008 | 11:07 PM
ZoSo-Green's Avatar
Originally Posted by ronjenx
A cooler thermostat will not reduce under-hood temps. The engine will not burn less fuel, so the heat generated will be the same. Besides, the exhaust manifolds are what probably gives off most of the heat under the hood.
Ahhh. Good point.
Old Aug 8, 2008 | 01:26 PM
Camojeep's Avatar
Default Undrehood Heat
I cut the weatherstripping from the back of the hood/cowl. Just the area behind the battery area. This leaves a nice gap for the heat to escape. So far I have not had a problem with the rain running in.
Old Aug 8, 2008 | 06:50 PM
The_Captain's Avatar
Thumbs up
good idea, why didn't I think of that? I was contemplating puttin' more holes in my Jeep.....
and your air box is in the front, so water won't get that far ahead......
Old Aug 9, 2008 | 12:20 AM
deconstructionist's Avatar
Originally Posted by ZoSo-Green
Does anyone know what temp the factory one is? Has anyone tried that?
I **Believe** it must be a 195 or maybe 190. I've added a scangauge to my jeep and I'm consistantly getting temps (once warmed up) between 197-203 degrees while crusin' and a *high* of 213 degrees while stuck in stop-n-go traffic for 1.5 hours
Old Aug 9, 2008 | 04:34 AM
scottrock's Avatar
What about ceramic coating the exhaust manifolds? Anyone tried that?
Old Aug 9, 2008 | 07:53 AM
WRAITHYJEEP's Avatar
Originally Posted by Jose Dosil
I think it came out on the Late 2007 Models,I might be wrong but mine is early 2007 and no heat shield
thats not a heat shield it is a fire blanket, that has some noise deadening feature
the plastic clips that hold it up melt and the fibreglass cloth shield falls over the engine and smothers the fire.
i tossed mine
became soaked and full of mud and started to rest on the engine.
Old Aug 30, 2008 | 08:23 PM
naplesrubicon's Avatar
dude that wouldnt smother a match
its for sound and nothing else
thats why it only came on the more expensive models
did you actualy think that the x model wont have an engine fire? or the people at chrysler didnt think it was worth it to put out a fire in an x??
Old Aug 31, 2008 | 07:06 AM
cmpmacchia's Avatar
Wouldn't the heat shield act as an insulator in the summer making the engine compartment even warmer?:thinking:
Old Aug 31, 2008 | 07:44 AM
see all this dude needed was a hood insulator and this would have never happened
ID:	12401   Click image for larger version
Old Sep 1, 2008 | 07:16 PM
JKCobra's Avatar
The heat shield did come on the X, I have an 07 with it, while my friend's 08 X model doesn't. It was a line change on the vehicle if I understood correctly (i.e. some 07 models were made with, then design change during production / cost cutting, etc., they stopped putting them in). A lot of people have just been pulling them out, I will probably will when I get around to it.
