Installed Solid diff covers last night. need some help
Old Apr 21, 2017 | 07:27 AM
Cjcain's Avatar
Default Installed Solid diff covers last night. need some help
Hey guys,
I installed the solid diff covers front an rear on a 17 JK hr edition. Dana 44 front and rear. What is the correct amount of fluid.I used lucas 85W-140. I filled about 3 in the front and 4.5in the back. I noticed fluid on the ground this am. Not from the pumpkin. Found blow back from im guessing the beather tube. any suggestions?
Old Apr 21, 2017 | 07:43 AM
63expert's Avatar
Originally Posted by Cjcain
Hey guys,
Which covers?
Do they not have fill level holes?
That is probably more than double too much.
Old Apr 21, 2017 | 07:57 AM
Cjcain's Avatar
Originally Posted by 63expert
Which covers?
They do have fil level holes. They are the spyntec Solid dana 44 diff covers.
Old Apr 21, 2017 | 07:58 AM
jedg's Avatar
Vet Army
Yep, you've over filled them. When you switch to a different cover, you just have to figure out what amount of fluid is going to get to reach the bottom of your axle tubes.
With a factory cover, the amount is below.
Front Dana 44
1.35 quarts
Front Dana 30
1.3 quarts
Rear Dana 44
2.4 quarts
Old Apr 21, 2017 | 08:06 AM
Canvas's Avatar
Veteran: Navy
Hey guys,
Do not fill your diff's to the fill port on aftermarket diff covers. This will over service the diff and can cause the inner axle seals fail due to the high pressure.
R/
Will
Old Apr 21, 2017 | 09:52 AM
Cjcain's Avatar
So I was told to run two qts for both front and rear. will let ya'll know monday what happens. or Ill be asking on how to rebuild the seals.
