JK Rear Brake Pad Replacement Write-Up
Old Feb 7, 2009 | 04:32 PM
Muffins's Avatar
Very useful write-up, thanks!
Old Feb 7, 2009 | 05:00 PM
renegadelt1's Avatar
Great write-up thanks, Mine are not due 6700miles but I will be taking them apart to try to stop them from squealing after the get warm they start when coming to a complete stop from 10mph down, The dealer says “cannot recreate customers complaint” maybe bevel the leading edge and some stop squeal spray will do the trick.
I have noticed a lot of brake dust on just the rears.
Old Sep 26, 2009 | 10:43 AM
MikeReo's Avatar
ok...this is driviing me nutz. I just replaced pads and rotors. Everything was done correctly as far as I know. I have probably done 20 or so brake jobs on various cars and trucks. New rotors and ceramic pads. Used a synthetic grease on the pad retaining clips and still have a loud squeel when I apply the brakes. The sqeal sounds when I first apply the brakes and goes away as I press the brake pedal harder. I think the squeal is coming from the fronts. I have given the jeep a week for the brakes to "settle" but still have the damn squeal. I could see this happening if only pads were changed but theres brand new rotors as well. Anybody else have a similar expirience? I would appriciate any insite you guys could provide before i pull everything apart. Thanks, Mike
Old Sep 26, 2009 | 11:49 AM
Trail Bud's Avatar
i get this too, from the old brakes and now the new one are starting.
on the new ones it's like you said; it's when first put pressure on the brakes then it goes away as more pressure is applied.
my squeal pulses too.
Old Sep 26, 2009 | 12:14 PM
MikeReo's Avatar
Trailbud...its enough to make you nuts...right? Maybe somebody will chime in with some help. I just dont want to take everything apart because i really dont know what to look for.
Old Sep 26, 2009 | 03:17 PM
Trail Bud's Avatar
I was pulling the wheels and brakes every 3 weeks or so to re gease everything. it would help for a few weeks then it's back.
it drives me crazy
I had pad left on the old ones, but I thought by putting in new pads and clips and greasing everything it would fix it. It did for 3-4 weeks
BTW; This is on the rear.
hopefully some body might have found a fix or at least a cause.
Old Sep 26, 2009 | 03:30 PM
mkjeep's Avatar
I used that red spray coating stuff on the back of the pads, let it dry, then applied the grease. Still has a squeak every once in awhile , but not all the time like it used too.
Old Sep 26, 2009 | 03:38 PM
MikeReo's Avatar
sprayed the pads or rotors?
Old Sep 26, 2009 | 03:45 PM
Trail Bud's Avatar
I used that stuff too on the pad backs , and clips too.
It did the same as the grease basically.
Old Sep 26, 2009 | 03:48 PM
mkjeep's Avatar
back of the pads, same places you put the grease.
