JK Throttle Body Removal/Cleaning
#201
I am going to do this due to some rough idle issues I have been having. Couple questions first. Step 1 disconnect battery. If I remove the tb completely can I spray tb cleaner in to the tb or should I apply using a rag? It sounds if the tb valve moves I should be ok. Do you think using some brake cleaner sprayed into the tb to finish it off would be ok to make sure all dust and other grime is blown out since brake fluid dries quickly?
#202
#203
So using brake cleaner will not harm the TB? Since it's plastic I didn't know if it would damage it. I think I will feel safe and buy a can of TB cleaner. But if you guys says that using brake cleaner is Ok then I dont have to buy a thing. And yes I have been experiencing idle problems around 500 rpm. Pepe has almost 85000 on him.
#204
#205
Originally Posted by JGP4JK
I dont know bout break cleaner but if you get some B13 Carb and Throttle Body cleaner, it will do the job very well. I soaked mine in Sea Foam Deep Creep spray, let it set for 5 minutes and then blew it all off with the B13. Only needed a shop towel to while off the excess. Looked like new when I was done.
#209
Originally Posted by MotiCross
Did mine about 10 days ago. Doesn't anyone else have this annoying whistle after cleaning it??? Driving me crazy...
#210
I'm going to be doing this in the next couple days as well as a new K&N Air Filter, NGK Double Platinum Spark Plugs, Mobile 1 Oil Change (No idea what the previous owner did). I'm new to doing most of this kind of stuff, should I do the TB cleaning, sparks, and K&N Filter all at separate times with a short 5 minute drive in between to help the computer out? Or a one shot glory of everything at one time?
![crazyeyes](https://www.jk-forum.com/forums/images/smilies/crazyeyes.gif)
