KC c3 3" led light install
Old Oct 1, 2015 | 01:03 PM
dienastyy's Avatar
Question KC c3 3" led light install
Hey guys,
Just purchased a pair of kc c3 3" led lights for my windshield. I opened the box to find no instructions lol. I'm not the most electric savvy person but I can figure a lot of things out with the help of YouTube. I was unable to find an installation video or write up on here so I was lookin for some help. My main question is the kit fine with just the regular wiring harness, or do I need to purchase a relay? This is what the box came with Click image for larger version
ID:	626100Click image for larger version
ID:	626101Click image for larger version
ID:	626102Click image for larger version
ID:	626103Click image for larger version
ID:	626104Click image for larger version
Thanks!
Old Oct 1, 2015 | 01:37 PM
14Sport's Avatar
I just googled them and the total watts are 16 so just over an amp of draw. I'm sure manufacturers would not ship lights with harnesses that aren't capable of handling the draw. It's a liability thing. You should be fine hooking them up directly but if you want to add a relay that would be okay too.
And welcome!
Old Oct 1, 2015 | 03:21 PM
dienastyy's Avatar
Thanks for the quick reply! Does anyone have any instructions on the wiring set up?
Old Oct 2, 2015 | 02:18 AM
14Sport's Avatar
They didn't come with instructions?! That's odd. Here's how accessories are typically wired when not using a relay. I would lay it out on the floor and see if you can get everything connected together. Power usually comes from the battery to an in-line fuse then to the switch where it's marked as 12V. Then out of the switch where it is marked ACC to the light positive. Light then either returns the ground to the battery or chassis. The third pin on the switch goes to the nearest ground under the dash. The second light is usually powered from the first light.
So from the picture it looks like it should be this but run all the wires externally first to test it. Once it works install the wires permanently. Let me know if you have any questions.
Name:	No Relay Accessory Wiring.jpg
ID:	626174   Click image for larger version
Name:	C3 (Medium).jpg
Old Oct 2, 2015 | 04:56 AM
dienastyy's Avatar
Wow thanks so much for the details. I'll try this out and let you know if I have any problems!
Old Oct 2, 2015 | 05:14 AM
14Sport's Avatar
You're welcome. Good luck but you won't need it. Let me know how you make out.
Old Oct 2, 2015 | 06:54 AM
urmyboyblue's Avatar
Veteran: Navy
For what it's worth, those lights are pretty slick! Have them mounted on my bumper and they'll definitely put out some light!
Old Oct 2, 2015 | 10:46 AM
BadBry's Avatar
Send them back with CLEAR INSTRUCTIONS OF HOW TO REFUND YOUR MONEY.
My other advice is to buy an SPod or equivalent. Makes wiring of accessories a safe task.
Old Oct 4, 2015 | 02:20 PM
dienastyy's Avatar
so i just finished installing the lights, everything went well till i turned them on. The bottom 2 lights on the passenger side aren't working, everything else is working as it should.
ID:	626312Click image for larger version
ID:	626313Click image for larger version
ID:	626314Click image for larger version
ID:	626315Click image for larger version
are my wires clean enough? or should i move them somewhere else?
Old Oct 4, 2015 | 02:50 PM
Veteran: Navy
Speak with whoever you ordered them from. I'd bet that the LEDs are bad. That shouldn't happen.
EDIT: saw your other post stating these are used. I'd speak with Amazon. That's why they're cheap. Two LEDs are bad.
