Maglight Holder for Rear Rollbar
Old May 11, 2010 | 03:55 PM
rickyj's Avatar
Default Maglight Holder for Rear Rollbar
Didn't know if I should combine this with the other thread or not, but decided not to step on the other posters toes.
I used a piece of 1 1/4" PVC pipe and sanded in the edges so that the light would drop into the pipe without knocking off the button. Then cut two pieces of aluminum plate rounded the edges a little bit and drilled the holes. Then bent the ends of the plate, put the bolts in and done. I painted the pipe bright orange, which seemed like a good idea at the time, probably the beer, but will probably change it to the blue I used for the instrument cluster and heater bezels.
And sorry, no pictures of the process since I kind of just make stuff up as I go along. But simple, holds the flashlight in an invisible area that is easy to get to and out of the way of cargo. Since I had all the stuff, the cost was zero.
Old May 11, 2010 | 07:10 PM
sm_rubi's Avatar
Dude nice job! Had to move my Maglight because of my fire extinguisher so I wish this write up was posted up sooner. Might redo it now!
