Making enhanced Rubi rails 4DR and 2DR
Update - i heard back from the welder and he should be getting back to me tomorrow with a rough price. I might have him weld 3 supports instead of 2. Why, i dont know? I'm not a big guy, just think it might look cool. Hopefully, if I get it done he'll let me hang and watch the mock up to see how it might look like that. will let everyone know.
Do those rock rails (rubi ones) just bolt to the body? If so then I can understand the flex.
Great write up, would love to see the underneath pic. I may make my own after seeing this for my Sahara. One with the pretty plastic step for my wife.
Jeep recommends pulling them when going off road.
I do have a couple ideas on how to reinforce them though. The best part is it's a pretty simple idea. I just have to stop being lazy and try it.
Just to give you an idea:
Both rubi and plastic step mount to the body in the same way but the plastic steps don't flex. So with that in mind, it's not the body flexing. It's the difference in the step vs the rail. So whats the difference? Simple enough if you compare the two you'll see that the step's three main brackets are boxed on 3 sides. The rubi rail's is a flat bracket that only has a small stamped ridge down the center (to help strengthen it). I think if the sides of that bracket were boxed in they would be just as stiff as the step's.
But then again, I'm really not to worried about the slight flex flex. Like I mentioned before, someone has already pivoted over rocks on these.
I can probably get some underneath pic.s for you also
So i went to the welder this morning but he did not have a working pipe bender, so I will have to go back to him later in the week. But we took the factory rails off, measured and determined where the supports will go.
He had 1.75" steel tubing but truthfully, that looked very fat and I think 1.5" would look better. Have people who have done this mod really used 1.75" tubing?
If anyone has more pictures of their project that they could email me directly I would appreciate it...Just PM me and I wil give you my email.
Thanks, I'd appreciate it, thank you for the explanation also, very thorough.
I too think that 1.5" tubing is more then enough. If your worried about strength my tubing is .120 DOM and it has hit a few rocks pretty hard and did not budge.
The only thing a would recommend is putting them at a slight upward angle like RedRockJK's over having them flat.
These are my rails and the same guy did mine and RedRockJK's.
