Oil Pan Removal / Installation
Old 08-24-2014, 07:30 AM
HiHoSilver's Avatar
So I read 105 foot pounds instead of inch pounds and snapped on the the rear bolts... How screwed am I? Or will I be ok?
Old 09-21-2015, 09:20 AM
bobwinn's Avatar
Default Sequence for tightening oil pan bolts?
Seems to be important (stamped on the oil pan itself) but cannot seem to find it.
Old 01-09-2016, 11:30 AM
ullearn's Avatar
Funny not funny, I just did the same thing - https://www.jk-forum.com/forums/stoc...9/#post4176557
How did you fix yours?
ID:	634147   Click image for larger version
Old 01-15-2016, 04:47 AM
Mojo_JK11's Avatar
What size are the bolts for the dust cover?....I recently discovered that one is missing....and when I went to the dealer to get a new bolt, they couldn't find which one it was that I needed. The guy didn't want to bother checking under the jeep to help find out what I needed.
Old 03-20-2016, 06:38 PM
kell490's Avatar
They look like 8 or 10 MM Mine leaked again after replacing the gasket so the 2nd time I used ultra black silicone on both sides of the gasket all the way around and never leaked again so advise is don't just do the corners go all the way around. Also don't put oil back in and start it for 24 hours that is another typical mistake with silicone people want to run it right away.
Old 03-21-2016, 06:44 PM
catahoula's Avatar
I know old write up but sweet! Glad this came up. I need to do this.
Old 03-21-2016, 06:45 PM
catahoula's Avatar
Would the oil pan gasket be covered under the power train warranty?
Old 03-21-2016, 07:00 PM
HiHoSilver's Avatar
No it wouldn't be
Sent from my iPhone using JK-Forum -- Northridge4x4
Old 03-21-2016, 07:11 PM
ronjenx's Avatar
No it wouldn't be
Why would you say no?
It's listed in the covered items.
Old 03-23-2016, 05:57 AM
catahoula's Avatar
Hmmmm might have to go in. I'm close to the end of mine
Quick Reply: Oil Pan Removal / Installation
