Old Man Emu 2" Lift Installation Write-Up
Old Jan 2, 2011 | 09:20 AM
  #111
blndspt's Avatar
Thanks!! I have the same lift. For 35's, it wasn't quite high enough when off roading. So, I ended up installing ACOS' front and back. With the ACOS adjustments, it sure runs nice now!
Old Jul 23, 2011 | 12:26 PM
  #112
Dittman2564's Avatar
Originally Posted by swisherd
I have a 2dr JK that has had the OME HD lift on for about 9 months now and I am also running 33's. I have noticed that whenever I go forward from the parked position that a loud clicking sound occurs, which sounds like metal-to-metal contact. I noticed that the shocks can rotate very easily 360 deg so I tightened those up and it took care of the problem several months ago, but now it's back. Do I just need to keep retightening them as this issue reoccurs? Also whenever I am driving on bumpy pavement I can hear a metal-to-metal rattle, sounds like something is definitely loose, but I have tightened everything to no avail, any suggestions? Thanks for your help.
Vr,
Dave
My traction control was activating after I completed my install of OME kit and it sounds terrible when on a dry paved road, so I reset the computer by disconnecting the battery for 10 minutes or so then reconnecting battery and drive vehicle for 20 to 30 minutes or more. Maybe try that?
Old Jul 23, 2011 | 12:27 PM
  #113
Originally Posted by cell4soul
I have a 2 dr with a Teraflex 2.5" coils on 35's. Once I installed the Rock Hard rear bumper, I am not happy with the sagging rear springs. The rock hard rear bumper is extremely heavy. Will the OME HD springs help eliminate the sagging?
I recently installed the OME H.D. lift on my 09 Rubi Unltd. I have a lot of weight front and rear, (ROCKHARD Bumpers front and rear), but I have shaved some weight as well. My stock springs had collapsed so badly the front bumps were touching and rear had very little clearance.
I didn't measure to compare,but I did not get as much lift as I had hoped. I used the 1/2" spacers in front. And the (slightly under) 2" rear bump stop ext. I have Bushwacker fenders so plenty of room but only 3" of travel before rear bump stops hit. More in front but have not measured. I used a P.p . Fr.Adj. T.B. which I set at 1/4" longer than stock bar. My T.B. and drag link are parallel,fact. rear t.b.-rear Track Bar is not at much angle at all,rear P.P. Track Bar brace on frame end,have a P.P. rear T.B. Bracket but it relocates and my T.B. would be near horizontal if I use it,and a few other unimportant items.( My fr. and rear ends were not off center by much if at all. I don't think I really needed any adjustment because I got less lift than a lighter rig). I was waiting for my p.p. fr. Lower Adj. Control Arms but it drove fine,no problems. Highway and back roads,with and w/o a load, and dirt tracks no bump steer no wobble,just smooth and much better than stock with the xtra weight.
I received my C.A.'s and installed them. All recommendations I see and the instructions said adjust to 23 1/4", my factory arms were 22 5/8" I went with 23" c-eye to c-eye. I test drove it,no problem. I drove it last night with slight load,and in a turn I hit a minor bump or pot hole and got major D.W. I an thinking I need to shorten front lower arms,close to or at stock length. I live not far from P.P. and a guy from there met me in town with some of my back ordered parts. He verified that my lift was an inch or so lower than "norm". I have 1/4" thick bumpers and winch with rear tire/can carrier,hi-Lift,Pull Pal,tools/necessities etc... I am thinking of adding spacers. Maybe changing 1/2" front to 3/4" in front and 1" in rear. Or 1" in front and 1 3/4" rear. If you haul camping gear,trailer etc.,you need a bit more rear height.
Old Aug 6, 2014 | 12:06 PM
  #114
rozzman10's Avatar
Bump back to the top. Looking into some OME springs. Wanna see and hear more about them.
