Pro Comp Light Bar Instal directions w/Pics
Old Oct 23, 2007 | 07:34 PM
  #21
jk4door's Avatar
Originally Posted by REL1203
For this type of light bar, whats teh best type of lights to get as a Kit? I have the factory fog lights, but want more lights (for looks and for practicality). Do I go with Fog lights, Driving lights, or long range lights, and what brand do most people get, KC, Delta, Hella?
Anyone have an answer to the above question? I'm also wanting to k ow the same thing.
Old Oct 24, 2007 | 07:21 PM
  #22
REL1203's Avatar
I guess no one does :(
Old Oct 27, 2007 | 07:01 PM
  #23
Rargo's Avatar
I used the KC SlimLite Series Driving Pair 130W Ice Blue Halogen in Titanium Finish and the install was easier then I expected. The wiring harness is perfect fit. I used the plasting conduit to cover wires and routed along existing harness. I am very pleased with the light output and they look great!
Old Oct 29, 2007 | 07:44 PM
  #24
jk4door's Avatar
What fuse location has everyone been connecting to? It said to use the accessory fuse location, but I didnt see that anywhere. Please help!
Old Nov 1, 2007 | 08:27 PM
  #25
SFD1248's Avatar
bringing it back to life. With that bumper can you still mount a winch on the front? A winch is on my to do list. I am either going to mount it on top of the stock bumper or do the behind the bumper that is in the write up section.
TIA
Andrew
Old Nov 8, 2007 | 07:48 PM
  #26
RevyJKU08's Avatar
Originally Posted by jpaddict
Excellent write-up, and thank you. I have been looking at that exact bar myself. I have a pair of Cibie Oscar+ ready to go.
You should consider replacing your stock headlights with the Cibie Euro-code lights as per my write-up several months ago.
Any chance you can have the KC lights wired into the high beams? Would you locate the highbeam fuse and the as soon as you flick on highbeams these lights would kick in and visa versa??? Is there a write-up for this procedure???
Old Nov 9, 2007 | 03:07 PM
  #27
onlyone's Avatar
You run the white wire in the KC harness from the switch, to the green/white headlight wire.
Old Nov 9, 2007 | 06:50 PM
  #28
Sv650's Avatar
Most jurisdictions will require that these type of lights:
a) be able to be turned off independent of the high beams;
b) light only in concert with the high beams.
That said, I always used a SPDT center off for my brights one side connected to the high beam wire, the other live, so I could run with them on independent of the high beams if I wanted.
SV
Old Nov 9, 2007 | 09:24 PM
  #29
sgmrock's Avatar
Very clean!!!
Old Jan 10, 2008 | 08:52 PM
  #30
Terp411's Avatar
Just installed KC lights today....let me know if you want to see pics of the wiring and switch configuration. It was pretty easy....most of my time spent making the wiring look really neat.
