Spark plug removal
Old Dec 9, 2019 | 09:30 AM
A. Favela's Avatar
Default Spark plug removal
So I scrounged the old interweb to find the easiest way to replace the spark plugs on my 2008 JK in particular the one by the passenger side firewall. I found that using the 5/8 spark plug socket along w the 3/4 socket and a short extension was all that was needed to get that badboy out. I also sprayed the plugs w WD40 the day prior just to make it a bit easier to work with.
I read and watched videos that recommended taking out the the battery tray, removing the front fender o just taking it to the dealership.
The way I did it was so much easier and cut all of that fender removal shenanigans from the picture and saved some time. Hope it helps
Old Dec 9, 2019 | 10:46 AM
karls10jk's Avatar
So you came in at it from the top? I cheated and pulled the fender flare and liner out. You can look directly at the plug.
Old Dec 9, 2019 | 12:29 PM
A. Favela's Avatar
Yup, I knocked it out going at it from the top. It was very easy to do so as well. I used a rubber vacuum line attached to then of the plug to get the plug back into each hole initially to avoid cross threading as well. Then finished off w the plug socket.
I'm not to familiar w taking fenders off. Seemed too time consuming for me. But if it works it works. I just wanted to put another tool in everyone's toolbox.
