Stopping people from opening your hood into the windshield for $6 or less
This can go in the "write up" forum or just stay here I had noticed numerous people complain about the dealers and other grease monkeys opening the hood of their shiny JK and resting it on the windshield.
BAAAAD JUJU
I like to add my OWN fawkin scratches, thank you. And I would prefer them NOT during an oil change.
Simple solution: Limit strap.
Simpler solution: self RETRACTING limit strap
Best solution: one I do not have to make.
I think "WAYYYTHEFUCK outside the box" on Jeep stuff. Here is a simple $6 solution to this issue.
Most hardware stores carry this nice self retracting chain style limiting device with tempered spring loop containment system and self latching auto-back with high polish chrome finish..
Or, A Retractable key chain..
They are $6, buy 2 when the first one rusts out in a few years
Please note pre-existing hole in fender.
Insert clip back into said hole. Real hard huh?
Slip key ring over "hood insulation tab" as shown and add a zip tie to prevent movement.
and TAAADAAAAAAA OMFG!!11!!!
simple solution.
Any questions, comments or concerns for today's class on thinking outside the box?
No, this will NOT prevent the wind from whipping it back or any kinda force but it is OVIOUS and you would have to put some effort to snap it.
BAAAAD JUJU
simple solution.
Wow I haven't had a hood problem yet but I will be running out in the morning and getting myself something like that before I take my Jeep in for it's first service.
Ya, I know its a Jeep and they get scratched and dented but I would like to be the cause of those dents
some oil change places and dealers like to be lazy and open the hood and rest it on the windshield. There have been a couple threads here of people a little pissed as scratches on the hood and windshield frame from it.
Friend of mine on his TJ installed a second pair of the rubber hood bumpers that support the windshield when folded down and positioned them to support the hood against the top of the windshield when folded all the way back. Sometimes it is nice to fold the hood all the way back to provide more light in the engine compartment and more room for access. I would guess that mechanics would simply disconnect the limit chain when they need access.
Good idea, but I'm willing to bet that the tab will bend on the hood before the chain breaks. Those little chains are pretty stout, the weak spot is the peened end of the eyelet, it wears out by the swivel action. I think in this case the weak spot is the open end of the eyelet. It may also interfere with the required service to the plugs, brake and clutch systems. At that point it'll get disconnected (yanked) off the hood, and then the hood closed down on whatever is sticking up.
I did a direct approach and walked out in the shop and asked the guy to not flip the hood to the windshield and pointed out the prop rod. It was free and now the guy knows I care about stuff like that. But he probably spit in the oil later when I wasn't looking. Hope it works out good for you, good luck!!
I'm thinking of painting the prop rod a really obnoxious color along with an outline around the hole in the hood, and maybe an insert rod here sticker.....
