Sway Bar Motor Flip (illustrated)
Old Nov 16, 2010 | 06:49 PM
  #21
jboth's Avatar
Found another writeup with pictures:
ww.wanderingtrail.com/Mods/JKmods/Disconnect_motor/Discomotor_flip.html
Old Nov 20, 2010 | 09:59 AM
  #22
EzK's Avatar
EzK
New pics would be nice. I'm trying to figure out the ideal drill spot.
EDIT: Winged it.. hopefully nothing falls apart.
Old Nov 29, 2010 | 01:27 PM
  #23
rinkishJK's Avatar
ill post pics of mine shortly.. i did this over a year ago so i cant show step by step...
Old Nov 29, 2010 | 01:42 PM
  #24
rinkishJK's Avatar
I am showing what u have to do to the mount with another bolt to rotate it.. hope this helps!
ID:	105781   Click image for larger version
ID:	105782   Click image for larger version
ID:	105783   Click image for larger version
Old Nov 29, 2010 | 01:46 PM
  #25
rinkishJK's Avatar
Forgot one... u will need to trim the plastic by the fan so the edisco plug clears it.
Old Dec 11, 2010 | 10:41 AM
  #26
betjeep09's Avatar
Question
Where did all the pictures go?
Old May 2, 2011 | 07:42 AM
  #27
highwayman's Avatar
I was able to reuse the bolt, after tapping the lower hole w/10x1.50, there was enough room in the rubber bungee. I didnt bother w/the bending, a couple minutes w/a sawzall took care of the clearance issues. I dont planning on ever running it hanging down again & trimmed off the bolt hole / ear on the disco that was pinned underneath the cover after the flip. After all this time w/the JK, I cant believe they havent mounted it like this from the factory.
Old Jun 28, 2012 | 09:47 AM
  #28
Bluesteal's Avatar
to late to get the pictures....
Old Jan 14, 2013 | 05:31 PM
  #29
justinstoffregen's Avatar
Originally Posted by yellowjeeper85
yup, its been repaired under warranty, replaced under warranty the new one has been repaired under warranty, now i'm waiting for them to replace this one under warranty... my warranty is up in 4500 miles, when it breaks after that, i'll have them flash the computer so its just no longer active and the dumb light wont blink all the time, after that, i'll convert to manual disconnects...
I have experienced the same fu**ery with mine. It's usually under repair. Warranty up in 2014...sorry for the hi-jack. Just wanted to commiserate.
