Tailgate shock project Done!!
Same project. I chose to use the Ball Joint shocks, and standard Ball Joint Brackets. I used Nutserts to mount the brackets to the sheet metal. You could easily through-bolt the brackets behind the Subwoofer. Access is easy by removing the taillight. I had to use 1/2" spacers for both brackets. All parts purchased at West Marine. A 40 Lb. shock is better, as there is less leverage with this approach.
Would you happen to have a part number list of the stuff you got from West Marine? I checked their site and saw the small, medium, and large pneumatic kits, but they had no weight rating on them. Any help would be much appreciated. Great mod! Looks very clean too.
[QUOTE=RedRockJK;70396]Woods,
Can you do me a favor and give me the measurement of the angle brackets I've marked here? (Distance from the mounting surface to the tip of the angle bracket just past the ball socket.)
Thanks!
Looks like 1 5/16"
Thanks!
Looks like 1 5/16"
I was looking today and found all the parts online for this for less than $20. (I think. So long as these parts are the same) Check out reid supply and let me know what you think.
Part #
GAS-132
GAS-201
GAS-303
Part #
GAS-132
GAS-201
GAS-303
You guys are fan freakin tastic! I spent a few hours tossing and turning in bed how to engineer something like this last night after getting whacked in the head while bending down near the subwoofer. Now I've got instructions, images and a parts list! Incredible! I'm almost afraid to go out to the garage for fear that somebody will be out there installing one...
Thanks!
Thanks!
Thanks!
Thanks!
Excellent mod....my parts are on the way.
For you Mcmaster-Carr fans the parts #'s are....
4138T573 (Stainless Steel Bracket with Ball, correct length no spacer required)
9512K12 (30lb Gas Cylinder with 10mm Steel Ball socket ends)
Total: $27.49 plus shipping
Thanks guys!
Thanks guys!
I missed that one!
